Auto off problem after lollipop update
Cyrus1
Hi guys recently i updated my xperia t2 ultra to lollipop and from then on my device has totally become useless. Everytime i turn on my phone it automatically gets off in a few minutes. After doing some research on the internet i ve found out that its not only me having this problem. I request sony to fix this as soon as possible maybe with another update.
Others having the same problem may also join this thread.
Tags (1)
@Cyrus1
Indeed, contact your Local support to get your phone inspected
14 REPLIES 14
@Cyrus1
I have a T2 Ultra running lollipop and I haven't experienced this problem, repair the phone with PCC and report back
PC Companion (PCC)
Bridge (for Mac)
Cyrus1
I did everything from hard reset to software repair via pc companion but it did'nt work.
@Cyrus1
Do you have the correct SIM card size? do you experience the same if you boot on >> safe mode
Cyrus1
Yes i do have the correct sim size. Yes the problem persists in the safe mode too. Prior to the update the device was working fine.
@Cyrus1
Let's narrow down the problem,  could you try to repair your phone again with PCC ? also remove both SIM and SD cards, does it reboot?
PC Companion (PCC)
Bridge (for Mac)
Cyrus1
Okay! Will try that too. Will let you know if it helps.
Thank you.
@Cyrus1
I hope it works
Cyrus1
It isnt working Slightly_frowning_Face . Updating a phone and especially a sony device is really a dangerous task it seems, it totally ruined my device.
@Cyrus1
Remove both SIM and SD cards, do you experience any bootloops?
