Apps on SD not visible after connecting to pc as USB drive
Hi
i have problem
if i connecting my arc s to pc to add some files to my sd card ...and from the phone home all apps installed in sd card not visible ..only i can see and use this apps if i remove usb cable or make it only on charge mode ...
Nabeel
it only happens when you connect in MSC mode
so connect in mtp mode as slim said
( settings> sony ericsson> connectivity>usb connection mode> MTP)
6 REPLIES 6
santam1
well it's normal so nothing to fear.....:smileyhappy:
check this thread.....
http://talk.sonymobile.com/message/49704#49704
Suze wrote:
When you connect the SD card to the PC and mount it, it becomes part of the PC as an external drive and therefore not part of the phone, so yes perfectly normal for the phone not to 'see' it during this proceedure.  Once you disconnect it becomes part of your phone again and the phone can see it and give you the details in the Storage section you were looking at.
hope you got the answer...if you got any more quarry keep me updated...:smileylaugh:
and don't forget to mark my answer as correct and helpful....:smileywink:
slimshaddy
Hero
connect your phone in mtp mode Slightly_smiling_Face
you can still transfer data in mtp and use your apps also...
when you connect your phone... drag the notification panel and select change connectivity..
Nabeel
thanx ..yes you are true but actually i using MIUI Rom and i don't finde this option Anguished_Face
Nabeel
:smileyshocked:, i AM sorry but i am not using this MIUI rom,  so don't know what the options are there
Go through all the settings and see if could find something related to MTP/MSC
slimshaddy
Hero
did you see my reply Dizzy_Face
