After Updating to ICS in Xperia MINI
Before ICS update
     I am facing issue of automatically wokring of back button issue.
After Updated to ICS
    I am facing,
1. WiFi is not working properly.
2. Hanging and Restarting Issue.
3. Battery is not withstanding as like GB os.
Please let me know solution for this?
Sathees
profile.country.PH.title
MarlonUk1
1 & 2 could be fix using repair SUS or PCC
8 REPLIES 8
MarlonUk1
Nabeel
As nolramlb suggested
All 3 issues might get solved after reinstalling your phone's software
Here is how
________________________________________________________________
m4dj
As other mentioned here ...repair with SUS. If my phone works without any issue and much better than GB, I don't know why yours wouldn't Winking_Face
About captive buttons.... I had the same problem for half year. This is related to captive buttons that where too much sesitive to temperature. The problem has gone after flashing GB to ICS. To be on safe side I have done repair with SUS.  Wi fi acquisition of ip address works 2x faster than GB.
Frommy experiance with ICs I can say that I think a repair with sus will solve your problems.
there are other threads with step by step how to do this Dizzy_Face
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
After repairing thru PCC (PC COMPANION), ICS updated again without any Existing Apps, Contacts, SMSes.
Issues 2 and 3 solved.
WiFi is connecting, I able to browse/use internet required apps for minute or two then Apps says no connection Retry or Browser says timed out. But still Phone shows WiFi is connected.
Sathees
m4dj
Did you try to connect to some other wi-fi point / router  and see how it works ?
I made my laptop as WiFi Hotspot (Using Connectify software) then I connected the mobile to that. It is working very fine.
But still I able to connect to WiFi Device Directly but it is not working after some minutes. when GB os WiFi Device and phone working very nicely.
Thanks.
mmrmartin
After updating my xperia mini to ICS (with factory reset) I had same issue with wi-fi as you described in point 1 (a lot of time outs, although wi-fi icon showed that my phone is conected to routrer).
I made it again working (as in GB) disabling WMM (Wireless Multimedia) - subset of the 802.11e - in my router configuration.
I hope that Sony will fix it soon, because I need to connect to wi-fi routers whitch have enabled WMM by default.
