1- I installed AVG antivirus after my McAfee trial license expired , if i uninstall McAfee how can i restore it again ?? and is it bad to have more than one antivirus ???
2- Sometimes the phone becomes very hot when charging or being used for a long time , is it normal or something is wrong ? if it was something wrong , how can I avoid the overheat ?
3- How to stop -apps which make the phone vibrate - from vibrating ?
4- When i open Facebook on time scape this notification appers "could't connect to facebook tap here to retry " , but twitter and the other time scape apps are working very good , how can i solve this proplem ?
5- How to block apps from using internet with background data ?
6- Is Jelly bean or ICS avillable for XPERIA U ?
7- If i upgrade the phone's system to a newer version of android , will the phone become slower or not
8- Is it harmful to install games with big size or not {like asphalt 7 or FIFA 12} ?
Thank you and very sorry for my poor English
1- Sometimes it's so bad !!! Remember that,Xperia U has only 512mb Ram,so why you afraid of viruses so much ?! one antivirus is enough !
2-to avoid that,take your phone in a hard place like wood tables or metal tables when you want charge it and don't use it when it's connect to usb or charger !
3- Check app's options or if it's a system's app,go to the setting
4- use the last software updates,maybe SONY fix that
5- Some apps have an option to avoid that,and you can also use some app to do that for you
6- ICS availabled for Xperia U with Some SI numbers,but for some others ,didn't come yet
7- Sometimes it become faster,but sometimes it's so awful !!! It's SONY :smileygrin:
8- No,but don't play when it's become so hot !!!
Enjoy
1. What was the point if you have the app that has same function.. It will waste your space..
2. It was normal for smartphone to overheat..
3. Check the app option
4.Maybe timescape problem or your connection
5. ICS is availlable for Xperia U in some region.. JB not yet
6. Nope.
Enjoy
THANK YOU VERY VERY VERY MUCH
you're welcome
