Xperia M5 vibration problem
Muhammetkby
After I updated my phone to android 6.0 problems had shown, vibration is not working and also some sensors for use vibration not working please help ๐Ÿ˜ž ๐Ÿ˜ž
6 REPLIES 6
Emil
Enthusiast
Hi @Muhammetkby,
I'm sorry to hear this. I recommend that you try and reboot your device to safe mode to see if this is caused by one of your downloaded apps as these will be temporarily disabled in this mode.
Once in safe mode you can test the vibration function in the diagnostics tool. To do so go to: Settings > About phone > Test > Diagnostics > Vibration. How does the vibration function behave here in this mode?
Also when you say that some sensors used for vibration are not working, could you elaborate what sensor you are referring to?
Let me know how it goes!
Muhammetkby
Accelerometer and ear proximity sensors are not working too
Muhammetkby
Vibration is not working in the safe mode also
Muhammetkby
I solved my problem on the phone again in this forum I found the fault is that the stamina is open I turned off stamina and I did the test test everything is working normally
Emil
Enthusiast
Great to hear it's working! Slightly_smiling_Face
I'm sorry I overlooked that STAMINA mode can cause this behavior.
Let me know if there is anything else I can assist you with.
Embun
Hi, I have same problems with vibration, ear proximity and accelerometer too.
When incoming call it doesn't vibrate too.
My STAMINA mode in off mode, I've been trying in safe mode too and doesn't work too.
Could you give me some advices?
This some screenshot from my M5 dual:Screenshot_20170521-185423.png
Tags (2)
