Hey guys, I have buy Xperia M one month ago and it's works perfectly.
but this morning I have found problem from my phone about standby estimasted time, it show 17 hours estimated time though my battry level is 99% Is this make sense?
here's screenshot:
and for your information, it's happen after I charge this phone.. I have also restarting my phone and it did not change the battery level.. hope someone here will tell me and help me to troubleshoot this problem (I mean my problem hehe :smileyrolleyes:)
**add: I have also disconnect all connection to packet-data (WiFi, mobile network, GPS, bluetooth)
*sorry for my bad english
guys, i have bought c1904 one month back. it is a good fone. 1. at starting it was showing 3 days 13 hours standby time in power save mode at 100% charge. but from last 8 days it is showing only 1 day 8 hrs standby time at 100% charge. 2. when data connection is on, subway surfer hangs.
There is a Simple SOLUTION For this annoying bug Just Clear the Data Of the Application!
FOLLOW the Steps Below>>
1. Go to Settings
2. select "Apps"
3. swipe the screen twise left to go to "All"
3. Then Find ""Extended Standby Mode"" and Open it
4. Then ""Force Stop"" it and scroll down and press "Clear Data" Then "Ok"
5. Finally Reboot(Restart) Your Xperia M
then every thing is fixed.. and the Stamina Mode will work fine and the Estimated Standby time Also
hey can you help me out with display and personalization and Stamina mode
I upgraded my phone and having a problem in display...
i dont like white background... and now after the upgrade complete settings is white
and QUARTZ theme is MY Favouriate and it's now present in the Android 4.3
And my battery is also draing fast even in stamina mode... i only use wthatsapp and fb..
Or is there any way to revert this update to 15.2 version (i tried factory reset)
plz help
