why xperia m 4.3 with firmware 15.4.A.0.23 not support theme?
and why xperia keyboard not have a phonepad layout?
why?
I came from Indonesia and maybe i just got unlucky
I'll create a backup of the Spider man apk and post it here and see if you can install it via your file manager
Try this - If it works then you have a regional restriction https://drive.google.com/file/d/0B-yM_qnM8ZPRV3pQc1k4MlV5ZGc/edit?usp=sharing
This is what I get:
ok....... please do one thing download sci-fi.apk file and install...... that app is required. then u can download xperia m theme...................................
@sreenath wrote:ok....... please do one thing download sci-fi.apk file and install...... that app is required. then u can download xperia m theme...................................
And where do I find it?
The Sci-fi theme is a paid for theme
@Thommo wrote:The Sci-fi theme is a paid for theme
Ok forget the theme, do you think Sony will push a firmware update to our Xperia Ms to fix this?
I've no idea - I get asked many times the same type of question and as I don't work for Sony my only reply can be to ask Sony care on the following link http://www.sonymobile.com/global-en/support/contact-us/
Someone in xda make a fix for this.
http://forum.xda-developers.com/showthread.php?t=2697369
but you need unlock bootloader to flash it or root to manually move it.
The other way is to wait sony to release another firmware.
