SD card gets corrupted after Marshmallow update
Ashay
Since Marshmallow (6.0) update on my Xperia M5 Dual SD card showing corrupted. but previously it was working fine on the lollipop.
after formatting the SD card in the safe mode, Phone detected the SD card.
but i cant copy paste anything into it.
when i use camera (data storage is set to SD card)  pics are not saving on SD card, it is showing "There is some problem with your data storage"
I checked the SD card it is working in all other phones.
Any solution Please ..
76 REPLIES 76
delixis
Mine too.  After update, I set the camera to use sd card for storage.  Again after 2nd shot, the message came up "There is a problem related to SD card. Please check it".  After press ok,  it will quit.  Only this problem found, so far.
This issue is the same as with the previous FW.
Trimond
There is a new update : 30.2.B.1.21
Just updated yesterday, This update has fixed the corrupted SD card issue
Been using it for a while now, so far so good
Some people have been complaining about battery drain after the update, I haven't experienced it so far
Better late than never!!!
JoshJustDied
The build update 30.2.B.1.21 which was released last week fixed the issue as far as i've checked. The update is 650MB more or less, after the said update, i turn the phone off, removed my SD Card and reinserted it on my phone. I tried to check the audio, videos and image files on my phone, they seem to be working fine, I also rebooted the phone to double check, no more " Corrupted " message after boot and files seems to be okay.
AORster
New
Still no solution to this? I've tried three different SD-cards they all get corrupted after a while.
JoshJustDied
Have you tried updating your Phone's OS to the version stated on the above posts? if so, then format your SD card and transfer your files back to the newly formatted SD card. That should do it. If you haven't installed the said update yet, i suggest you update first.
AORster
New
Doesn't seem to be avilable for Sweden.
Got it confirmed now that it is not avilable for Sweden yet. Face_with_rolling_Eyes
Ramixperiac4
Same problem here... I tried all kinds of check disk nothing works!
Restarting makes it work for a while then gets corrupted again
I'm going to root my SONY E5333 PHONE ONLY BECAUSE OF THIS  MARSHMALLOW UPDATE
Thank you sony.
DEAN23
AORster Ever heard of a program called Flashtool? I hear its a problem solver for this type of issues....
DEAN23
Ramixperiac4, strange, cos I updated it a couple months back, and it has been working fine since - are you sure it's not your sd card the problem?....
Epicurean
No issues here, even though I use a storage card split formatted for adoptable storage (which should increase the risk).
