SD card gets corrupted after Marshmallow update
Ashay
Since Marshmallow (6.0) update on my Xperia M5 Dual SD card showing corrupted. but previously it was working fine on the lollipop.
after formatting the SD card in the safe mode, Phone detected the SD card.
but i cant copy paste anything into it.
when i use camera (data storage is set to SD card)  pics are not saving on SD card, it is showing "There is some problem with your data storage"
I checked the SD card it is working in all other phones.
Any solution Please ..
76 REPLIES 76
Yanzkee
I had the same issue with you, that time (about 2 weeks ago). then i checked my Sandisk ultra 32 Gb to my PC and i found that my ext SDcard corrupted, then i reformat it with somebody advised software (Mini partition wizard) then problem solved,and of course i've lost my all files in there.
Yanzkee
Would u please tell me what sdcard u used? I mean the brand and it size. Just for recommend to me.thanks
lichawang
i just bought a new m5 dual... 3 days ago, after updated 30.2.B.21. this problem pop out ! ! can't be fixed!!! how long we have to wait!?
TomCZ
My SD card is corrupted after software update (v. 32.3.A.2.33).
Phone: Xperia Z5 compact
card: sandisk extreme 64GB (1 month old card)
Before the update I haven't experienced any problem
Any suggestions?
jary
34.3.A.0.228 is not fixed
Chas66
The card is not corrupt, the OS just decided not to like exFAT format anymore.   If your SD card is 64gb or larger, you will need to partition it into 32gb chunks to be able to use the FAT32 format that Android 6 requires - at least on the Sony Xperia phones. Use a PC to partition the card
titokmashudi
It also happened on my C5 Ultra dual, after the Marshmallow update, the phone can not read my sd card. It can be read when I inserted to my Z5 Dual.
So I format it with free format & partition software (in my case Easeus Partition Master). Format the sd card to FAT32, it worked like a charm...
