Could you elaborate the issues please? Does the GPS work at all?
Have you tried resetting the phone software after you updated it? If not, I would recommend that you give it a try to see if the problems persist.
Hi @Mojso
Have you try clear the cache/data of your GSP application?
Perhaps the information of this link can also be useful in this case:
By resetting I mean reset the phone software (Settings > Backup and reset > Reset) and not just restarting the phone.
I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
If the issue should still remain I think that this needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
