data with USB help
OPGELOST
swt
Bezoeker
data with USB help
how to use mobile data on computer with the help of USB cord .
for model no xperia  mdual  c2004
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
Jake-SonyXperia
Kampioen
Hi swt,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Make sure you also have the appropriate Internet settings before performing a Tether to the PC.
Menu > Settings > More > Internet Settings > Accept Disclaimer > Select Network.
Once done follow the instructions in the link above.
Bekijk de oplossing in de community in het oorspronkelijke bericht
10 ANTWOORDEN 10
Jake-SonyXperia
Kampioen
Hi swt,
swt
Bezoeker
dear ,
in my phone there is no Accept Disclaimer
plz. help for setting for how to use mobile data on pc
goelaakash90
Bezoeker
Do this
1) Connect your phone to Computer via USB
2) Go to Settings>More>Tethering & portable hotspot
3) Check USB Tethering
4) Computer will install drivers and ask you set a new network
5) Choose any one of them (Preferably home network)
6) Computer will automatically configure the settings and you can start browsing.
Done
swt
Bezoeker
dear friend.
my phone c2004 m dual .having charging probleme .
i submit the phone to sony service centre . dt 20.3.15. aurangabad maharashtra.
but  probleme is same & under checking.
already i cahnge the cahrger & usb cable sony make.
solution about this
swt
Bezoeker
mobile is return as it is without repairing from authorised service centre .
charging probleme .
can c2004 xperia able to charge with wireless charger .
if yes , which charger.?
phone battery is ok .
problem  in phone pin where the charge pin attached.
if we adjust the pin mobile is charge .
charger & usb cable also new sony make.
pl. suggetions
goelaakash90
Bezoeker
What is the problem exactly?
Is the charging slow or no charging at all?
swt
Bezoeker
dear sir,
it's charge but need to adjust the pin wher we joint at mobile end.then it charge.
charger & usb cord also new sony make
goelaakash90
Bezoeker
Most of the smartphones today use the same kind of charger so use any other one.
If your phone charges correctly, then the problem is with your charger.
Otherwise it is a problem with the handset.
The service centre will probably change the USB point in your phone.
