Can't set up the settings of NFC
Paulol1
Hey everyone here can you help me how to set up the NFC settings?
12 REPLIES 12
ckahlo
Under 4.1.2 extended length APDU support over NFC worked like a charm. Now with 4.2.2 "Transceive errors" occur everytime an extended length APDU (longer than 261 Bytes) is to be transferred. Seems someone put in old drivers (libpn544_fw.so) and/or old Nfc.apk.
This renders the phone finally unusable when you're using intelligent RFID chips for authentication.
Bad update.
ckahlo
Found it. You guys put the wrong (old/broken) libnfc.so into the Android 4.2.2 update. Taking the old one and exchangig that makes the phone working again. BTW: The Xperia M can be modified the same way. My SP, Z and Z1 have to small antennas to give useful test results with our tags.
pawan55
nfc was working lyk a charm in 4.1 update
bt after updating it to 4.2 it stopped wrking.
is dis a hardware problem or software issue?
thanks in advance
