Bluetooth
Thomas301
Member
Bluetooth
I have the NHS Covid-19 app which requires Bluetooth to be enabled as you'll see from this screenshot. Can I enable Bluetooth to come on at startup?.Bluetooth stay on screenshot..png
4 REPLIES 4
Piscie
Community Team
Hey, have you tried to set up the app permissions from the phone Settings? If not, make sure that Bluetooth is enabled, you can get that by pressing on Settings - Apps & Notifications and select the Covid-19 app, then select permissions and toggle the Bluetooth option to On. That will make the Bluetooth option remains ON, then you will have to turn it off manually. Hope that helps :slight_smile:
Thomas301
Member
Blue Tooth does not appear in the app permissions or notifications as you'll see from the screenshot.
EMS_MO72
Community Team
Hi there,
When you first install the App, did it ask you to allow some permissions for the app?
In anyways, you can try to reset app preferences and try gain.
Thomas301
Member
I'll try re-installing the app and see what happens.
