audia4t : Moving post to new thread due to different problem
Are you still having troubles getting the two rear speakers (Rear Left, Rear Right) working?
JohnMcLean - Just confirming: Other than reading the manual to set it up right, all is good at the moment?
If not, Im happy to try and help, but have got confused in the 2-threads in one - but need more information such as what speaker setup you are using and connections to where. etc.
Cheers
Just connect to the SURROUND not REAR SURROUND..then use the calibration utility with the calibration mic plugged in.
If you then want to use the extra connections you can use them for a number of options which you choose i.e Bi-Amp,Rear Surround or Front High setups.
Don't forget its a 7.2 device, so those connections are left unused ...unless you have a 7.2 requirement.
My front speakers are capable of Bi-Amp, so after I got it all working 5.1 , I changed the front speakers to Bi-Amp operation.
