Sony STR-DA5300ES
profile.country.en_GB.title
evertonmonkey
Sony STR-DA5300ES
Hi in the manual on page 28 for my Sony STR-DA5300ES is says :
"HDMI IN6 is input which is considered sound quality"
What exactly does this mean ?  Are the other 5 HDMI ports not exactly the same ?
hardeepr
It's Sony's shocking english translation :wink:
But seriously - it had bugged me for years as well but I eventually found the answer. Basically HDMI6 is routed internally to reduce the amount of interference to enhance audio quality so if you have a high quality audio source  (eg SACD or DVD-A) that is one you should use.
4 REPLIES 4
hardeepr
evertonmonkey
Thanks for the reply.
so using a blu-ray player, should that go on HDMI6 or any ?
hardeepr
Not sure it matters to be honest - I stuck mine into HDMI1 of my 5300ES and it sounds great.
evertonmonkey
Great thanks for that "correct answer" goes to you :wink:
