Condividi la tua esperienza!
Good afternoon All
Just bought a Blue Ray BDP-S1100 here in Italy with the plan to use it here and then take it to the UK next year.
I was under the impression that I should be able to see Netflix and BBC Iplayer but they don't seem to be installed.
Any suggestions ?
Thanks
John
In italy those application are not available. In order for them to work you should not only set the country as UK but you have to have a UK IP when connecting to internet.
Many thanks, IP not a problem but how do I set the country ?
You should reset the BDP and restart the setting from the beginning.
