Como gravar a partir das saídas digitais do UHP-H1 para um DAT DTC 59ES ?
Desculpem mas é simples, basta regular as saídas digitais para 48KHZ. Devia ter lido o livro de intruções.
Hi there
Glad you've managed to solve it yourself and posting the answer too.
Can I please request that you type in english next time around, as this is an English based forum.
Cheers
Sorry, now Sony community it's a bit confusing. OK, on the audio settings I chose the 48 KHZ option, since my DAT doesn't support the 96 KHZ and 192 KHZ options. I was talking about the digital outputs and I wrote that I should have read the manual. Cheers.
