hello,
my phone Xperia E3 restarts frequently and it shows " unfortunately camera common has stopped". even touch screen and power button is not responding. i am facing this problem since 2 days. could you please help me.
I am unable to use my phone. As it is permanantly flashing camera coomon not working. I press ok then it says ok again, the pop is not going.Please help
Currently experiencing the same problem. When I press OK, I cannot make pattern anymore for the password of the phone. May i know the solution on this. I've been scrolling the thread but I did not found any solution mentioned.
Appriate help on this, please
Thank you.
There are two approaches mentioned by @CameronT:
- Clear cached data of your Camera app.
- Perform a software repair using Xperia Companion (backup your data first).
i have same problem with common cam.
How backup data before factory reset?
@sriparna wrote:hello,
my phone Xperia T3 restarts frequently and it shows " unfortunately camera common has stopped". even touch screen and power button is not responding. i am facing this problem since 2month . could you please help me.
my Sony Xperia e3 camera is not working from 4. Days
Re: unfortunately camera common has stopped this problem still continue after so many time sofware repair from authorised sony servise center and my ph software currupt after 5 to 9 days every time when it repaired and servise center employee tell me to change my motherboard but it not available because ph is very old so plz help me on that issue thats why im facing big trouble
