Is there an simple way to copy and paste photos from my PMB (calender) to a folder on my PC?
Hello mikejcb - Welcome to the Sony Forums
If you look for the default file folder (this should be visible by looking at the software settings) you can then navigate to this folder using My Computer/Computer/Windows Explorer and then manually copy and paste the files that you are looking for.
Thanks,
Simon
Thanks,
Simon
Thanks for the reply.
Although neither the FIle or Edit or right-click menu of PMB offers copy&paste operation
it is possible to copy&paste images from calendar view in PMB to other folders on the PC. Just mark the images and use the standard Windows short keys (STRG+C and STRG+V).
If you switch to Index View it is possible to move image to other registered folders of PMB too
Thanks for your reply also
