hi and hello!
my vajo-pcv v1/d has a pc-card slot, which i have never before used.
does someone of you know, if this port does work with a card adapter to establish an e-sata connection? i have also heard of express cards, which are some kind of progression in regard to the older pc-cards. is this pc-entrance still comparable or can it be updated?
thanx 4 your comments,
christopherid
Hi Christopherid,
Yes, you can get PCMCIA eSATA cards:
http://www.vantecusa.com/pdf/ugtst350cb-flyer.pdf
You can find adapters to use the smaller expresscards in a PCMCIA slots but I'm not sure this works with all expresscards or not.
blencogo!
thanks again for your immediate and clear response.
kind regards from vienna to britain,
christopherid
blencogo!
christopherid
