Persistent defect camera FDR-AX100E
Lubo1966
Member
Persistent defect camera FDR-AX100E, ľm desperate, improved software ubdate, please help. Link to video : https://www.youtube.com/watch?v=YxWA4UsF86k
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
Lubo1966
Member
Hi Articos .
I watched your video , and found there is no problem . Efect ( Moire ) occurs when dense horizontal or sloping surfaces , it's not a mistake , it's a sign of quality for higher ranked detil.To is not rated as a problem. Bricks 4K definitely enjoyable to read . Can you insert 4K video at least 50 Mbps.
Best Regards.
14 REPLIES 14
Articos
Member
Hello Lubo1966,
I have recent purchase this camera model, if you like send me your video config parameters when you see this problem for check and valuate it.
You have a Hight Quality Memory Card?. I use a Lexar Professional - 1000x SCXC of 128 GB.
Best Regards,
Articos
Lubo1966
Member
Please write me where you want me to send those (defect) video. I use these SD cards : SanDisk 64GB Extreme Pro U3 ,SanDisc 64GB Extreme PRO U1, 256GB Lexar Professional 1000x U3, Sony SF- 64JX 64GB U1. Card function properly. The problem is already visible on the monitor cameras in the control indication (Peak - yellow).
Articos
Member
Hi Lubo1966,
No, i alrready view the video defect in you sample.
I only need your config "image size", "format on recording", "frame rate"...  and other info,  for recreate your config and verify the problem.
Best Regards,
Lubo1966
Member
Lubo1966
Member
What version of the software pre-installed in the camera when you bought ?
Articos
Member
Now 3.10, i have upgrade from ver. 3.00
I have equal config and test it tomorrow.
Articos
Member
Hi Lubo1966,
I have check this problem, and yes i found this problem, but more lite, when change drastic focus over surfaces hight contrasted and/or "moire" textures.
My sample link: https://youtu.be/vswx_mpiLYo
Is not easy to resolve, Sony can upgrade software processor, but when...
Best Regards,
Lubo1966
Member
Thank you for the video . I have experience CPU does not respond to the situation correctly , the software is not fast enough . Dakto said it was working on the edge of the top, and therefore slow response when sharpening - especially visible when approaching ( contrast - much detail ) . Video for viewing : https://www.youtube.com/watch?v=SEwZj1svU_A
Look to the left side up , max resolution.
Best Regards.
Lubo1966
Member
Hi Articos .
Best Regards.
