We have recently purchased a Bloggie Sport. While impressed with the picture and video quality, there are a some issues that might make us send it back.
1. The last few seconds of recording are not saved. For instance if we are recording someone speaking and press stop at the end of the sentence, the last two or three words won't be saved.
2. Over a two hour period of recording today, we had to hard reset it (hold power for 7 seconds) 4 or 5 times after it refused to switch on. Not good for a device designed to record spontaneous moments.
3. Finally the battery life is disappointing.
Is anyone else experiencing these problems? If so, the first two issues should be correctable with a firmware update and possible the third as well. Is there any news when an update is due?
If it's just us, then maybe we have a bad unit and should get it replaced.
Hello captainsparky - Welcome to the Sony Forums
As you say that you have only had the Bloggie for a short period of time, it may be worth giving Sony Customer Services a call to see if there is an internal fault with your device. If this is indeed the case, you would then be well within the applicable period to get a repair or replacement.
The contact details are in the following forum thread:
http://www.sony.co.uk/discussions/message/651957#651957
Thanks,
Simon
Thanks,
Simon
