- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
setting ip address
Hi
does anyone know how to give a KD-49XF9005 a fixed IP address for use on wifi?
I have controls at the gateway and want to make an exclusion for the TV so as not to inspect the video traffic.
there is an option to set the IP address but it would appear to only work when wired.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
For more details on how to manually set an IP address for your TV, please see here.
Hope this helps!
Best wishes,
Sean Mc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It would appear the 49fx9005 falls under this category,
IMPORTANT: For certain models, it may not be possible to manually set the IP address when using the wireless connection option.
Which pretty poor any lazy design.
You can manually set the IP if using the ethernet connector which is not ideal.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can't say for sure, but there is a default IP address that is in different forms. What do I mean? I mean there are a lot of default IP addresses that depends not only on IP but also on routers. Yes. Each router has his own login and password. However, since there are a lot of them there is a database (192.168.254.254) that has almost all logins and passwords for each router. So if you want to learn more about it, feel free to check it out, dudes... P.S It helped me a lot when I faced this problem.
